1991 740 8v crankshaft pulley
pwaterman123
- Year and Model: 740 1991
my crankshaft pulley is moving to the degree it has cut into the timing belt cover. How do i adjust or remove (renew )pulley . single nut version is in centre of pulley thanks pete
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The crankshaft pulley is actually a harmonic balancer which in basic terms is a pulley with a rubber insert to absorb vibrations from the engine. Over time the rubber breaks down and the pulley can, as in your case, separate and damage the timing cover. The only remedy is to replace the pulley.
Do a search in the RWD forum for replacing the timing belt which explains how to remove the bolt holding the pulley to the crankshaft.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
