Hi all,
Color me flummoxed. I have been trying so hard to get the steering right on my 1996 960. Just bought it as a project and it is harder to steer left than right. It throbs (for lack of a better word) on a long left curve such as you would find on an off ramp. I have replaced the power steering pump and the steering rack and the outer tie rods. I have bled the system.
I have the same issue. Though maybe to a lesser degree. I have not had a chance to try it out on an off ramp which is the ultimate test. There is no question that it is harder to turn left than right. I can easily live with the harder left than right but not the throbbing deal. That does not feel very safe. I do not know, obviously, what this problem could be outside of the pump or the rack. Has anyone out there experience the same symptoms and dealt with it by something other than the above remove and replace op?
Thanks very much,
Jim Lee
1996 960
Flummoxed on power steering issue
have you corrected this yet? I picked up a "fixer-upper" that had steering/control issues. I found the the tie rod ends from the steering rack were installed improperly. One of the sides was installed upside-down. I flipped it and all was good!
wurkin4it
Michigan - Retired
89 240DL
00 V70 GLT
Michigan - Retired
89 240DL
00 V70 GLT
- 3331 Views
Last post by chittychittybangbang
- 4177 Views
Last post by jonesg
- 30 Replies
- 27419 Views
- 6160 Views
Last post by EngineeringBloke
- 1152 Views
