air conditioning compressor
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » S80 3.2 Transmission Fluid Change
belac
Year and Model: 84 - 240
Post by belac »
I have a 1984 240 wagon with a York compressor. the air is working fine but the clutch makes a lot of noise when the air is off. I seems to be moving back and forth a little when it is off and vibrating. Should I replace the clutch and if so is there a specific one I should get?
Retired MVS Contributor
Post by Retired MVS Contributor »
When the clutch is engaged and the A/C is operating the clutch is turning the compressor...When the A/C is shut off the clutch is disengaged, the compressor is not running, and the clutch pulley is turning on a bearing in the clutch...If the compressor is noisy when the clutch is dis-engaged, the bearing in the clutch pulley is going down and will soon seize, making it impossible to shut the A/C off...It won't be electricaly engaged but it will be mechanically locked because of the bad bearing...The only repair is to replace the clutch...It should be possible to do it withoout removing th compressor...Remove the air cleaner housing to gain working room...
The clutch is available from FTC Groton for $110...
belac
Post by belac »
thanks. do I need to use a torque wrench?
belac wrote:thanks. do I need to use a torque wrench?
No...Don't remove the drive belt until after you ramove the compressor's center bolt...That will help to hold the pulley from turning when you remove the bolt...
belac
Post by belac »
thanks for the help
Acecooper
Year and Model: Volvo 850 - 1997
Post by Acecooper »
jerrymcc wrote:When the clutch is engaged and the A/C is operating the clutch is turning the compressor...When the A/C is shut off the clutch is disengaged, the compressor is not running, and the clutch pulley is turning on a bearing in the clutch...If the compressor is noisy when the clutch is dis-engaged, the bearing in the clutch pulley is going down and will soon seize, making it impossible to shut the A/C off...It won't be electricaly engaged but it will be mechanically locked because of the bad bearing...The only repair is to replace the clutch...It should be possible to do it withoout removing th compressor...Remove the air cleaner housing to gain working room...
Yes exactly jerrymcc, I also encountered this problem a long time ago. I brought it into our nearest shop. The repairman told me that we need to replace your clutch.
online air conditioning
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Acecooper, welcome to Matthew's Volvo Site.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Volvo 240 Newbie
Year and Model: 240 DL 1990
Post by Volvo 240 Newbie »
Hello everyone,
My daughter was driving and smoke/smell started to come from under hood. Looked and smelled like clutch material.
There was a line of oil on the frame inline with the rear of the AC pulley and a hissing noise. I assume that leaking freon.
My question. Replacing the clutch will not correct this I assume?
Has anyone ever bypassed the AC compressor with a belt from crank, alt and waterpump to eliminate the compressor?
Looks like the belt from AC to powersterring is close to 1:1?
Compressor maybe on christmas list, but would still like to drive it.
Thanks
karibakid
Year and Model: 360 1985
Post by karibakid »
check ipd they have a spacer re air con belts just a thought cheers jack m
karibakid wrote:check ipd they have a spacer re air con belts just a thought cheers jack m
The IPD conversion kit will only work on early 240's that used the 2 cylinder York compressor...It will not line up properly on later 240's that used a variety of wobble-washer compressors...A different drive pulley was used on the power steering pump and the spacer that IPD supplies cannot be installed...
The problem is that the power steering pump is driven by the A/C compressor clutch pulley, so the compressor drive belt cannot be removed without losing power steering...A fix can be done by using one belt instead of two on the alternator and running the second alternator belt from the crankshaft pulley to the power steering pump...It lines up perfectly, but there is a caveat...The ignition timing marker lug on the timing belt cover has to be removed or the belt will rub HARD on it...
Jerry
