Stranded. Where can I order strut mount fitting and washer?
RallyRoadWarrior
- Year and Model: V70 T5 2001
Just had my struts replaced but the mechanic did not change the strut mounts. The front passenger upper strut mounts failed on me in the middle of the desert. Had to go to a local desert mechanic and he is having trouble ordering the final pieces. I ordered new strut mounts, bushings, and bearings but I need to replace the strut mount washer, fitting, lock, and cap ... It's the rubber washer and etc that is on the very top before the final nut. Already spent too much $$$. Where can I order this online/phone?!?? HELP!!! Need to get back on the road. Much appreciated in advance ....
JRL
- Year and Model: Several
- Been thanked: 16 times
Just use the old ones
Worst come to worst, just leave the washers off until you get to civilization and buy them at that time
RallyRoadWarrior
Unfortunately there isn't 'old' ones to use. The washer broke off when I was on some dirt road. I could not see the part of the strut sticking out on top! Essentially the tire was attached only on the bottom! And it seems the mechanic DID NOT use a proper nut when he replaced my strut!
I need to find the rubber washer that is on the every top of the strut bearing before the last bolt. It looks like a o ring gasket with 'volvo' on it
RallyRoadWarrior
Still stranded in the Mojave. Can the strut be put back together without the washer? Or is the washer holding it together at the top? How dangerous is it?
- 2027 Views
Last post by ThommyKent
- 14 Replies
- 6816 Views
Last post by erikv11
