New Kevlar timing belt. Different install procedure
This topic is in the MVS Volvo Repair Database » A Volvo Hot Hatch, Maybe?
iselloil
Year and Model: 1999 V70 XC AWD
Post by iselloil »
Bought the new kevlar timing belt for the wifes 1990 base model V70 I'm building for her.We did a diffrent install than bringing everything to top dead center.
We marked the cams at 12 o'clock.Put three marks on the belt at the twelve o'clock position, and a marked two groves in each direction.Pulled the harmonic balancer.Marked the crank pulley the same.
Pulled the belt,transfered the marks to the new belt.Installed the new idler,tensioner,waterpump,then the belt, matching up the marks.
A hour and a half we were done.This was after jacking up the car,and pulling the tire.
The kevlar belt is very quiet,and hope we get a little longer life out of it.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
bigwong
Year and Model: S70 98
Post by bigwong »
How will you know you get longer life, unless you run it until it dies, and then it's too late. It may also be outside the 2-3 standard deviations from average life, so you also wouldn't know anyway.
Anyway, good luck with the new timing belt, and keep an eye on the water pump.
iselloil
Post by iselloil »
I Did the water pump.From what I read about the belts,is the big thing thay dont streatch as much,and are more durable.The main reason for going with the new belt is this is the car the wife will be on the road with, not that I'm trying to run it over the required run times recommended by the MFG.
1999 V70 XC
Mobil 1
K & N Filters
Ceramic brakes
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The belt will probably long outlive the tensioner. Don't, however, test the life of the tensioner. It won't last much past its recommended change interval.
'98 S70 T5
2016 Chevy Cruze Premier
thecheat
Year and Model: 1996 850 Turbo Wagon
Post by thecheat »
jablackburn wrote:The belt will probably long outlive the tensioner. Don't, however, test the life of the tensioner. It won't last much past its recommended change interval.
I don't think the kevlar belt is designed to be an extended change interval part. Just a stronger belt for higher performance engines and still replaced at 70k.
jblackburn
AND it will stop bullets! Just in case you ever feel like wearing a couple...:mrgreen:
'98 S70 T5
Papii
Year and Model: 850GLT1996
Post by Papii »
Hi jablackburn,
Do you have any idea on change interval for these tensioners and idlers? I've just had the timing and accessories drive belts replaced yesterday without changing them. Thanks. :)
thecheat
Post by thecheat »
Isn't it every other belt? I bought the whole magilla for my upcoming belt change (2nd belt) in a week or two.
jblackburn
Early 98's and pre-98 cars can be changed every other belt change - mid-late production 98's and 99's and later must be changed EVERY belt change (since the interval is longer anyway).
'98 S70 T5
Papii
Post by Papii »
jablackburn, thanks a great deal for the information. :D
