I recently installed a set of hid's (aftermarket), no burnt bulb warning for the first 10 seconds, then poof, both lights went out and the burnt bulb indicator illuminated. I turned off the ignition, then on again, this time only one light came on, so after about 4 attempts, both of the headlights stayed on with no warning. But sometimes one or the other or both lights go out??? I then ordered a code harness from the same company as the hid's, NO difference.
Has anyone had a similar problem, and if so were you able to fix it? I thought it might have something to do with the DRL's, or just a cheap hid kit? (DDM Tuning).
Thanks, Roncop
