Speaker sizes
Tie Rod Brands: Which Will Last Longest?
VolvoFreak
- Year and Model:
Speaker sizes
I'm finding conflicting information all over the net about this. I want to start replacing the speakers in my car and don't know what sizes to order! I have a '93 850glt with speakers in the dash, front & rear doors and on the rear deck.
VolvoFreak
- Year and Model:
Sweet.. That's what I thought. Any clue on the depth for the door speakers?
- Has thanked: 2660 times
- Been thanked: 1254 times
No idea on the depth of door speakers.
Dash takes 7" speakers.
VolvoFreak
- Year and Model:
7" on the dash!? Are you sure ('93 850glt)? The grills dont even look big enough for 4" speakers...
I got a pair of 5.25" Kicker's for the front door. They fit perfectly eventhough I needed to drill some holes for the mounting screws as the new speakers didn't line up with the factory holes.
I got that info from here
http://carstereohelp.net/speakersizesVolvo.htm
VolvoFreak
- Year and Model:
Wow, they are so wrong it's not funny! I pulled the grill earlier and there are maybe 2" tweeters in there, but I think with a bit of coaxing I can get 3.5" in the same hole.
rimshot77
I heard that I must buy speakers that have 8 ohms for the Volvo 850 not 4 ohms. Is this true?
VolvoFreak
- Year and Model:
Yes and no. The front door and dash speakers are 4-ohms. However, the read door and deck speakers are 8-ohms, but are wired in parallel. By doing this, and according to ohms law, by wiring 2 8-ohm loads in parallel, the amp only sees a 4-ohm total load. If you disconnect the rear door speakers, you can put a 4-ohm speaker on the rear deck though.
Code: Select all
Front door left -----------------> amp
(4 ohms each)
Front door right -----------------> amp
dash left -----------------------> amp
(4 ohms each)
dash right -----------------------> amp
rear door left ---
(8 ohms each) \
rear door right -- \
deck left ---------\--+-----------> amp
(8 ohms each) \ (4 ohm load)
deck right ----------+------------> amp-
