v70xc 2001 reduced performance message
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
weldboy0
Year and Model: v70xc 2001
Post by weldboy0 »
Hello:
I am new to the forum so bear with me. I have a 2001 v70xc. Car will run okay when cold. When warm reduced performance comes up in display message and car wants to stall. When sitting still idol will jump up and down by itself . When you shut the car off it will cure this for some length of time then it will do this again. Went to Advanced auto when this happened they put it on the scanner and came up with air mass flow, oxygen sensors front and back and catalytic converter . Haven't had time to get to a garage with better scanner. Can anyone give any help with which one to start with? Hope I am explaining properly......yes I am a woman.
Thanks for any help
priapism
Year and Model: 01 S60
Post by priapism »
First clean the MAF (throttle body). There's a tutorial on the site. It's a sensor between the air filter and the intake. A can of the cleaner runs like 7 bux.
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
there are too many codes at once. Indeed clean the MAF as suggested, but also clear all the codes and see which ones come back.
weldboy0
Post by weldboy0 »
Thanks I will try this tonight. Hopefully this will do the trick
