I purchased a 1996 Volvo 850 Turbo 145,000 mi, body ent were in excellent condition. The Turbo was shot, replaced turbo, serviced transmission, new belt, h2o pump, timing belt, flushed coolant and flused brakes. Car still smoked, chk engine light came on finally determined that charcoal canister pluged pls some valve on sytm, took care of check engine light, but still smoked. Repair shop replaced oil seperator. I still smell oil burning when exiting the car after running any suggetions. The mechanic says doesnt think we are getting blow by. so far into this thing for $5500 for car and additional $4000 for repairs.
Any ideas on why still smelling burning oil?
1996 850 Turbo Money Pit
White850Turbo
- Year and Model:
Is oil actually being used up? These cars aren't that expensive if you do all the work yourself. And the reason the turbo went bad at such low mileage is most likely from 2 things:New Volvo Owner wrote:I purchased a 1996 Volvo 850 Turbo 145,000 mi, body ent were in excellent condition. The Turbo was shot, replaced turbo, serviced transmission, new belt, h2o pump, timing belt, flushed coolant and flused brakes. Car still smoked, chk engine light came on finally determined that charcoal canister pluged pls some valve on sytm, took care of check engine light, but still smoked. Repair shop replaced oil seperator. I still smell oil burning when exiting the car after running any suggetions. The mechanic says doesnt think we are getting blow by. so far into this thing for $5500 for car and additional $4000 for repairs.
1. Using dino oil instead of synthetic
2. Not letting the car idle after long or hard runs, thus causing oil to coke up in the turbo's oil lines and allowing the bearings to operate without lubrication.
VolvoFreak
- Year and Model:
That's what happened to my parents car. The mechanic said that with the turbo's, to let the car idle for at least 30-seconds before shutting it off to let the turbo charger wind down or something like that.White850Turbo wrote:2. Not letting the car idle after long or hard runs, thus causing oil to coke up in the turbo's oil lines and allowing the bearings to operate without lubrication.
Are you sure that there isn't just oil on the block from the last oil change?
new volvo owner
I have seen the smoke also coming out of the exhaust when it idles for awhile, and I am quite sure that it is coming out of the exhaust. The tailpipe is very black, and the rear bumber above the tailpipe has dark junk on it. A friend @ work suggested driving on freway @70mph to get heat up maybe burn off any oil left over from turbo change out and all the other work done on car. Could there be lots of oil in the catalytc conv?
new volvo owner
Actually I am not seeing smoke now only the smell when I get out of car after running it. Could there just be a lot of residual oil in the exhaust system that would need to be burned out on a trip of 90-100 miles of continous driving?
White850Turbo
- Year and Model:
Probably not. From what I've seen, smoke at idle is a good indicator of a clogged PCV system.new volvo owner wrote:Actually I am not seeing smoke now only the smell when I get out of car after running it. Could there just be a lot of residual oil in the exhaust system that would need to be burned out on a trip of 90-100 miles of continous driving?
New Volvo Owner
I had the PCV system cleaned @least I thought I did. They replaced the oil seperator on the system and I assumed that would include cleaning of hoses. Is there anything else?
- Has thanked: 2660 times
- Been thanked: 1254 times
If your 850 is using oil and smoke is blue, could be rings. Watch oil level.
There should not be any oil in the exhaust system however if you have a leaking valve cover gasket or other oil leak it could be dripping on the hot exhaust pipe and burning off. Check for leaks!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
