A/C Cpmpressor kicks on, off, on, off ......
Sting
Post by Sting »
96 850 150K
I recently checked my A/C as it is already getting warm here in AZ. The issue I have is the compressor kicks on, for 3 seconds, than off, then on, then off, and repeats this pattern. I have checked my r134 level and it is showing full, any ideas what's going on here?
dosbricks
Been thanked: 2 times
Post by dosbricks »
That's what mine was doing on my '96 wagon when the coolant was low right before I had to replace the evaporator. :cry:
It's plenty hot here in the summer too.
tina
Year and Model: 1998 S70, 2001 S40
Post by tina »
How did you check the level? If it was one of those cheapo guages they don't work! I checked mine and it seemed fine, but then fit a whole can of leakstop/recharge in it. I used the "high miles" formula which helps slow leaks and boost performance of the cooling, and it lasted the entire summer. Was gone by next spring so you probably have a slow leak like I did.
