2002 V70 XC Wagon, transmission problems.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jbrauner
Year and Model: 1997 850 T5 Wagon
Post by jbrauner »
From the information I have gathered I am likely not alone in having an 02 V70 XC with a bad transmission. Mine has only 94k miles on it and after about 20 mins of driving the transmission will slip and hard shift especially when down shifting. The car drives like a dream otherwise and the trans shifts perfectly for the first 20 minutes. I have had both a Volvo dealer service center and an independent transmission shop say that the transmission itself is good but the valve body is faulty. My issue is that I could spend over $1000 to fix the valve body and find out the transmission is in fact the real problem. Maybe some other V70 owners have been through this and can offer some insight.
Thanks!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You need more than just a valve body, you need a complete rebuild or a new transmission
This is classic 2002 tranny failure
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
JRL wrote:You need more than just a valve body, you need a complete rebuild or a new transmission
Jim, please give the guy some hope, just a little please :lol:
JRL
Post by JRL »
If you can give me a good reason why I should lie to someone to give him "hope" then I would be glad to do so.
I've had four (4) 2002 trannies pack it in and this is the main symptom
virginiagrad
Year and Model: v70 2002
Post by virginiagrad »
My 2002 v70 had its transmission replaced at 30k (previous owner). Even if jbrauner replaces his tranny, as in my case, what is the liklihood of him (my) having problems down the road with a new tranny? For the record, my transmission shifts fine, though not as smoothly as other volvos I've driven.
priapism
Year and Model: 01 S60
Post by priapism »
^depends if the software was updated to the newest version or not. flush or drain / fill with the proper fluid and make sure the software is up-to-date, that's the best thing you can do to ensure your transmission's life.
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
