2006 s60 Blowing Bulbs continually
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Pabco
Year and Model: s60 2006
Post by Pabco »
Dear Reader
I have an S60 Volvo and love it. But since I bought it around a year ago every time I replace a globe, headlight taillight or other then about a day later the next bulb blows.
Is there a known problem with voltage overage or has anyone else heard of a similar issue
I would deeply appreciate some help as you take it to the dealer they replace the bulb and like clockwork it blows again and I am up to around 10 bulbs now.
Thanks in anticipation
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
check the bulb socket. Replace if it looks like overheated.
randyman
Year and Model: S60 AWD 2002
Post by randyman »
Yes, check the voltage with a meter at the battery with the car running. Should be about 14 volts. If it is 15,16,17 volts then replace the alternator. If it appears normal then turn on alot of electrical accessories and see what it reads. Also increase engine RPM's in both cases to see if it shoots up high.
Retired MVS Contributor
Post by Retired MVS Contributor »
If you are getting 16, 17, or 18 volts measured on the battery with the engine running, the alterator is putting out and is OK...The blown bulbs indicate a bad voltage regulator and it is all that you need to replace...A new voltage regulator would cost less than $100, while a rebuilt alternator would be $300...The correct output should be a little more than 14 volts...If the alternator itself were bad, barring noisy bearings, there would be no output at all and you would read 12.5 volts (battery voltage) with the engine running...Don't wait too long to remedy the situation...Over-voltage can damage the control modules...
