I have just to complete the full service of the engine and the only thing missing is a set of new spark plugs.
What do most people use in there engines? I do not run high boost so I don't need a colder plug. OEM spec is fine.
Are there any plugs I should avoid? Champion plugs in Saabs are a waste of money for example.
Best Spark plug for the 850 T or V70 ?
confused_al
- Year and Model: 1996 TLA wagon
You cant go wrong with OEM plugs (I think Bosch is the maker for turbo plugs). People here and in VS reported all kinds of problems with various other plugs.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- Year and Model: Many Volvos
- Been thanked: 76 times
I just use the plain old Bosch coppers on mine. Like Al said, you can never go wrong (at least yet) with Volvo OEM parts.
I think the old plug number I used was Bosch number FR7DC but they have changed their numbering scheme and I can't recall the new part number.
The gap is critical - 0.028 or slightly less
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
I like NGK plugs as they always make durable plugs. I just bought 5 OEM plugs made in Germany apparently for $35, is that average?
Life would be enjoyable if it wasn't so painful to live.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I like the Bosch FR7DC (aka 7555) in my '97 855 GLT. I had the OEM platinum plugs and found that if I started the car and ran it for less than about 1 minute, it would not start easily the next time due to platinum tip fouling. The copper FR7DCs have not exhibited this problem. I need to regap them about every year or so, so I usually just replace them since they only cost about $2 each.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The Bosch Coppers just don't last long enough for me. I was getting misfires after only 20-some,000 miles on my engine, so I decided to go back to the Autolite Platinums I'd run before.
I found that it's very finicky about the gaps with other plugs - I needed to set mine to .026" to keep it from occasionally hiccupping, but now it runs great! The Autolites get me better gas mileage than the Copper's too (and no, it's not my imagination - I drive the same route every day)
My car came with NGK's installed, and ran pretty well with them too. They're good plugs, those are the only kind I use in our Hondas.
'98 S70 T5
2016 Chevy Cruze Premier
Red-Arrow
Copper is a better conductor than platinum but copper is much softer and will deteriorate faster. Platinum is much harder and resistant to pitting and erosion but the spark is less intense by a very small percentage.
Where on Earth do you find plugs for $2 each?
Allen in Hemet
- Year and Model: 2000 V70XC SE
I have good luck /experience with Denso E3 plugs. They are pregapped, and the gap is not adjustable on these "Diamond Fire" plugs. I have been using them for the past year/approxamtly 15,000 miles with no missfire issues due to the plugs. R/ Allen
carboncow
- Year and Model: 2003 XC70 2018 S60
Guys need some input, hopefully I'm not truely hijacking.
What is the gap needs on copper NGKs? I tried the Bosch Platinum Plus (as recommended by FCP) and have had nothing but issues. The local autozone had this NGK listed as I requested a copper only option after reading so many posts.
Do I gap to .028 the same as the Bosch? Or is there something unique for a different plug manufacture?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- 3003 Views
Last post by Roger_850T
- 1929 Views
- 3168 Views
Last post by Bigbill55
- 3874 Views
- 4062 Views
Last post by Walru5
