99 V70XC : can I run without rear drive shaft?
davidschaffer
- Year and Model: 2003xc70?
Hello, I have a 99 V70XC, the rear drive shaft is shot, I can't afford to replace it at the moment and was wondering if any harm could be done in driving without it? I'd hate to ruin a computer. What happens when the computer sends a signal to a drive shaft that isn't there. Any first hand knowledge is greatly appreciated.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
- Been thanked: 3 times
I believe you can without harm. There is a guy here in Houston that runs one without the rear drive. In fact, he told me that they are much better that way. He's on Volvospeed a lot, you may try that board if someone doesn't chime up here. Although, I'd be surprised if someone here could definitively answer your question. I'll try to email him and see if there is any problems.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- Has thanked: 2864 times
- Been thanked: 1332 times
Here's a couple of topics that discuss how to remove the propshaft:
Remove Propshaft '98 XC70
Remove Propshaft '99 XC70
JRL
- Year and Model: Several
- Been thanked: 16 times
YES
No problem
No problem
davidschaffer
Thank you all for the replies. I will remove the rear drive shaft tomorrow.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Been running almost a year without mine, no problems.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- pkc303
Got email back from my friend, he has had no problems running two V70's without rear driveshaft. Good luck.
I have been running for more than a year without mine. In fact, last weekend I went one step further and removed both of the rear axle shafts. They were bound to fail some day, so I removed them.
I cut off the outboard ends of both shafts and faced them off in the lathe so that the hall effect sensor rings would be attached to the wheels and provide signals to the antilock brake system. I cut off both inboard sides and stuffed them back into the differential to keep the gearbox sealed. I drilled and tapped them and inserted cap screws in case I have to pull them out of the differential again. I posted photos of the stub shafts before installation to show the details.
Hope this helps somebody. Without this site I would never have tackled half of the jobs I have done on my Volvo.
- 3077 Views
- 5359 Views
Last post by SuperHerman
- 31 Replies
- 13329 Views
- 851 Views
- 942 Views
Last post by jrschwit
