what is my engine code for a 2001 T5?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
I'm seeing conflicting data when trying to order parts from eeuro and fcpgroton.
B5234T3 or B5234T5 or other?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
B5234T3
carboncow
Post by carboncow »
Thanks. Things started to point that direction for me...just seemed "odd" that a T5 code ends in T3!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
carboncow
Post by carboncow »
Otis...I'm confusing myself again.
So what I got from this info is the T-5 is a 2.3L engine based on this, correct?
I was doing the plugs today and noted 2.4 stamped on the head somewhere and found that interesting or most likely not relavent!
Now I'm quite sure that eeuroparts drop down could be wrong...but would you consider my car (2001 T5) the last option then even knowing it doesn't have the T3 designation after it and it's not an XC or type R
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
otis44
Post by otis44 »
I''m not sure about their drop down menu or why they have the cars listed as they do. For example an "R" model was not available in 2001. If your car is a T5 and is a 2001 model, you have a 2.3l turbo (B5234T3) engine. The only other engines available for the 01 model years would have been the 2.4 n/a (B5244S) and the 2.4T (B5244T3).
carboncow
Post by carboncow »
Thanks again. I new their drop down was messing with me! (along with that 2.4 stamped in the head).
I'm done over thinking this : )
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
Retired MVS Contributor
Post by Retired MVS Contributor »
The serial number and engine type are printed on a decal on the timing belt cover, and are stamped into the metal on the back side of the engine on the water pump mounting flange...You will need a light and a mirror...
