Car stalled at a red light, was running perfect before that.
Since then, I have replaced the spark plugs, spark plug wires, distributor cap, but still car will only start and run rough with a real foul gasoline smell for a minute or two then it cuts off as if it ran out of fuel. Attempts to start it again fail. Seems like it only starts right up after it's been sitting for a while. Could it be the fuel filter?
I noticed a pool of oil on the valve cover when replacing the spark plugs, but dont know why.
There is a clicking or knocking sound from the engine, but cant figure out or pinpoint the exact location, could it be the rotor?
While replacing the distributor cap, I noticed a donut shaped thing up against the engine, that fell off when I removed the old cap. I thought it was some type of seal for the cap so I just put it back when put the new one.
I dont know what else to try, and it's driving me crazy. Please if anyone has any advise, please post it here.
96 850 n/a issues
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
This sounds like a mass airflow sensor to me.
Undo the connector on the sensor just after the airbox, start the car up and see if it will drive around. If that's it, there's your problem.
The oil on the valve cover is probably a clogged PCV system. See the write-up at the top of the forum and read through cn90's post below mine for the NA engine. Once you've done that, you can replace your oil cap seal as well.
That donut is supposed to be inside the dist. cap; and the rotor itself shouldn't be making noise. If you can get a video of the noise or try to isolate it further with a "mechanics stethoscope" (a piece of pipe or something will help you pinpoint the noise) we can probably be of more help.
'98 S70 T5
2016 Chevy Cruze Premier
I will take check the mass airflow sensor after work.jablackburn wrote:This sounds like a mass airflow sensor to me.
I will try to get video as well.
Thanks man, I hope it's just the sensor like you said. My tags expire this month so I have to figure this out.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Better not,they aren't cheap and you will need ONLY oem volvo maf sensor which is Bosch 0 280 217 107.volvo_96 wrote:...Thanks man, I hope it's just the sensor like you said...
These cars don't like aftermarket electronic parts,especially sensors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I disconnected the sensor, started up the car and seems like it ran better. I then connected the sensor and engine would turn but it would not start. Disconnected sensor again, started up fine. I then connected the sensor while car was running and engine died. So I am afraid it's the sensor. Can someone second this before I spend the money on a new sensor?FCPGroton wrote:Sounds like it is the MAF to me also. I do hope I am wrong because they are not cheap but worst case, you could always get a used one.
jblackburn
Yep - bad sensor for sure.
If you don't have the money to spend on a new one (they're expensive little things), look on Ebay for a used one, someone parting out a car, or head to a junkyard!
Don't, by any means, go aftermarket, like something you would get at Advanced. I have seen people do that and only have more problems.
'98 S70 T5
jblackburn
That doesn't sound good; that noise is in no way related to the airflow sensor. I wonder if you've got a stuck valve that's been smashed.
'98 S70 T5
- 11 Replies
- 2569 Views
Last post by dimataeus
- 11 Replies
- 5992 Views
Last post by oragex
- 1898 Views
Last post by leapdragon
- 961 Views
Last post by hausmeister
- 519 Views
