Drive Shaft Loud ping noise
henrys200v70xc
Year and Model: V70XC, 2000
Post by henrys200v70xc »
Car: 2000 V70XC AWD
Problem: Loud pinging noise when i back up clicking noise when i slow down.
Mechanics have said: Front Coupler, bearings, and drive shaft might be out
Quoted me at $1077 for a new drive shaft. Found Coloradodriveshaft.com that i might use.
My Questions: Do i need a whole new drive shaft or just some part of it?
Where is the best place to go to find reasonable parts?
Can i just change it to FWD and drive it? (the car is in northern wisconsin far from anyone who has worked on a volvo)
thanks!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Wrong forum
Try the 850/70 forum
You can drive it forever in FWD
Just remove the propshaft then see if your noises go away first
It's a process of elimination, but R U sure you want to drive in WI in FWD... NOW, in Dec!???
henrys200v70xc
Cool, I just wan to get it from the north woods to a family friend mechanic closer by.
So should i delete this post and just post it in the other forum? (sorry im new to this)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Welcome to MVS.
You're fine. I moved this topic, and left a marker in the other forum that points here.
Here are a couple topics that discuss how to do remove the propshaft:
98 v70 xc drive shaft removal
Remove rear driveshaft- 99 xc70
Also -> Amazon link
clarkandrew45
Year and Model: 2008 Volvo S60
Post by clarkandrew45 »
Last month, my uncle visited a mechanic to test his front Coupler and bearings. He was asking for a replacement for both two because of some silly noise he was hearing. Upon the diagnosis, the mechanic found out that the problem was the drive shaft. He was advice to replace the drive shaft with a new one. We did what JRL said, to remove the propshaft and that saved us $.
clarkandrew45
Sorry I overlooked the thread! My mistake.
