check engine light
check engine light
My check engine light keeps coming on, i had the codes pulled and got ECM-715D. I know the code means that the ECM temp exceed 85 degrees. Has anyone had this problem before and do i change the temp sensor or i have a cooling problem
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
To me it sounds like the ECM module itself is getting too hot. Can you check to see if perhaps air is not being allowed to circulate into and out of the box which holds the ECM? I have attached a a .pdf files which shows where it is located. Let us know how you make out...
Print screen re ECM location.pdf- (500.94 KiB) Downloaded 166 times
