850 radio trouble shooting
Gabewillwin
Post by Gabewillwin »
i have a 97 850, with some radio problems. when i bought the car the radio didnt work. it displays "off" and when you hit the power the "off " display disapears. there is a power and alarm light incorporated into the stero and that blinks when the car is off. the appopriate fuses are not blown (the number 7 fuse to be exact). any idea if i can fix this with out buying a new stero? am i missing somthing?
Gabewillwin
i pulled the stereo out and there are two wiring harnesses plugged in and what looks to be an power or antenna out on the lower left side of teh rear of the stereo.
Jot
Year and Model: C30 2010
Post by Jot »
Call your Volvo dealer with your vin and get the radio code and enter it with the buttons .but first check your owners manual as the previous owner might have left the code paper that came with the radio.
Gabewillwin
i think i ofudn the paper with the code taped to the unit. but when you need a code doesnt the display read CODE? ill give it a try
Jot
Post by Jot »
The ignition needs to be on for about two hours before you will see the word "code" at which time you key in the four digit number.
