Smoke out exhaust on start up
TuHandy
Post by TuHandy »
Hello,
I just rebuilt my motor from bottom to top. It has less than 1000 miles on it and I am noticing a small amount of blueish smoke from the exhaust on start up. I replaced all the normal items rings bearings, ect., had valve job done, new valve seals, ect. Motor has great compression again. Checked the plugs they are all clean and dry.
I did not touch the turbo so I was wondering if possibly the internals of the turbo (like a seal) might be a cause.
Thanks
97 Volvo 850 T-5
200,000 miles and still going strong
TuHandy
Post by TuHandy »
I am still leaning towards a bad seal in the turbo. The smoke on start up is getting worse.
Does anyone know what type of turbocharger is in a 1997 850 t5?
I believe it is a Mitsubishi TD04, maybe a Garret, Not sure.
Has anyone bought a rebuild kit for thier turbo?
97 Volvo 850 T-5
8fiddy
Post by 8fiddy »
Hey I can't help you but I'm in Ellensburg, Wa. Google search turbos for the 850 and im sure you can come up with something.
Travis
TuHandy
Post by TuHandy »
Just ordered a turbo rebuild kit for a Mitsubishi TD04HL-15G, which my 97 T-5 has in it. The kit contains all the bearings, o rings, ect that you need to rebuild the turbo.
I pulled off the tube that comes off of the turbo compressor and I noticed a pretty good amount of oil residue in it, so I am pretty sure a bad seal in the turbo is the cause of the puff of blue smoke on start up.
I will post after rebuilding and let everyone know if that was the problem.
97 Volvo 850 T-5
