Replacing front rotors
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » Control Arm Bushings - Buy Whole New Control Arms?
strom19
Year and Model: S 60 2007
Post by strom19 »
Does anyone know where I can get directions on replacing the rotors on my S60? Thank you!
billr99
Year and Model: 2002 V70XC
Post by billr99 »
Its actually pretty simple.
1) Jack up car and remove wheel.
2) Remove caliper and bracket by removing the bolts (14mm ?) holding the bracket to the hub carrier.
3) Remove wheel locating pin (10mm) which secures the rotor to the hub
4) Remove rotor (if you are lucky it will nearly fall off when the pin is removed, if not you may need to use a bit of force with a suitable mallet).
5) Installation is the reverse. I would suggest using a bit of copper-based antiseize where the rotor contacts the hub to make any subsequent changes a lot easier.
This is one of the easier things to do on this car so have fun.
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
strom19
Post by strom19 »
Thank you! much appreciated :D
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Let us know if you need anymore help.
zooplane
Year and Model: V70 2003 N/A
Post by zooplane »
How about a V70? Is it the same???
zooplane
Post by zooplane »
2003 to be exact...?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Only one thing I would add about replacing them from billr99's excellent write-up is that if the new rotor is thicker than the old one (and it should be if you are replacing it, otherwise a machining would have done the job) you will have to push the piston(s) back into the caliper to allow the new rotor to fit into the (now smaller) gap between the pads.
