Hello guys,
I have a 1999 Volvo S70 non-turbo,
I was wondering if anyone had any idea to get a factory fog light kit for the car. I asked my Volvo dealer/service guy about it and he said its about 270$+ for a kit and to install it.
So, if anyone has any great ideas on what to do about fog-lights or the whereabouts on a factory kit I would really appreciate it Thanks!
Searching for Factory fog light kit.
Volvo 850 S2 Transmission Shift Solenoid Replacement w/Pics
JRL
- Year and Model: Several
- Been thanked: 16 times
FCPgroton sells good aftermarket lights at about $50 each but you're still going to need a dash switch and relay
(They may sell the relay, I don't know, the switch will have to be new (or used) Volvo)
You also need to buy the correct (for fog lights) bumper grills
reds70turbo
- Year and Model: 1998 Volvo S70 GLT
My 98 didn't have fog lights from the factory. I chose to add them roughly 2 years ago. The full kit from the dealer actually runs closer to $220 and includes very good instructions. Personally, I would go that route and install them yourself. The instructions are very straight forward.
1998 S70 GLT - 183K - full of fun stuff and meticulously maintained!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Hit up RobtheModd. He spent a few weeks on the sunbject of fog lights. I'm sure he can give you some decent advice about where to find them etc.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I recently submitted a request to Vands Auto Dismantlers out in CA that specializes in Volvo and Saab used parts. They quoted me about $100 for the two lights; I'm sure they can pull all the relays, etc for you too.
'98 S70 T5
2016 Chevy Cruze Premier
My 850 came with a set of T5 fog lights. The previous owner installed them but never got to wiring them. To bypass cost of the "special relay" and switch I pulled a standard relay from under the fuse box(not the expensive fog light relay) and a rear marker switch from a donor 850 at the pull yard.
The rear marker switch is essentially the same as the front light switch except for the wiring pins are off one position.
I pulled the switch illumination feed from the pre wired plug behind the dash. The rest of the wiring, the 12v key switched feed, ground, 12 v relay feed and the light feeds, I ran new. It looks and works like a stock setup.
Works great. Cost me about 6 bucks for the switch and relay from the pull yard and a few bucks in the wire and connectors.
They are not the brightest lights around but ....
- 11 Replies
- 108197 Views
Last post by BEJinFbk
- 1255 Views
Last post by goejimmy
- 15 Replies
- 2766 Views
Last post by volvofornia
- 1243 Views
Last post by 93Regina
- 2223 Views
Last post by DonVanhugenstein
