Labor on suspension?
upstate NY
- Year and Model: 95 850 GLT wagon
So I finally got my 95 850 wagon on the road last week. I discovered a broken spring on the rear driver side, my front strut on the driver side is loose, all around it is just a noisy bumpy ride. I would love to do the work myself but do not have all of the proper tools nor the time. What would be a safe estimate on the Labor for an all around suspension change? Parts I have an idea, I just don't want to get ripped off. Thanks for any feed back!
95 850 GLT Wagon 170,000, Mobil-1
94 850 GLT sedan 215,000
86 740 GLE wagon 140,000
Forgetting what lies behind and straining forward to what lies ahead. I press on toward the goal for the prize of the upward call of God in Christ.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
5 hours. It will take an actual 3.5 to r&r the struts and rear springs, in my garage at home without a lift. A Volvo tech can do it much faster, but you are paying him for his experience and peace of mind.
Klaus
zhenya
- Year and Model: 97 855 T5,98 V70 AWD
Sounds about right. Looking through my records, my local indy Volvo specialist charged me $570 total inclusive of tax to install all new suspension at 4 corners, sway bars, endlinks, strut mounts, etc and to do a 4 wheel alignment.
Where are you located? I spent $710 for above work. I'm in Baltimore MD.zhenya wrote:Sounds about right. Looking through my records, my local indy Volvo specialist charged me $570 total inclusive of tax to install all new suspension at 4 corners, sway bars, endlinks, strut mounts, etc and to do a 4 wheel alignment.
Klausc
In the Twin Cities, labor is now at $100/hr and the dealer is $130. Makes me wish I could go south for a good garage.
I asked for an extimate to replace the front struts, not the rear shocks, and the indie said $1100. Did it my self, an alignment cost me $100.
Klaus
zhenya
Upstate NY. The mechanic is a Volvo specialist though - so prices are generally lower than someone who hasn't done the job 500 times already. Well, that, and they are just fair all-around.bobice wrote: Where are you located? I spent $710 for above work. I'm in Baltimore MD.
if u wanted to make the slight invest ment and have the tools you will need
jack stands $30
floor jack $30
18mm Deep Socket
18mm closed wrench
13mm closed wrench
crescent wrench
spring compressors (which u can rent)
there are some other small things along the way but really id rather spend 200$ on new tools for my suspension job then pay some one else to do it.
on another note i recently replaced my whole front end and the biggest help is a torch to heat the rusted on bolts.
i bought everything through FCP including koni FSD shocks, total cost was probably about $500 but if u got for normal shocks your looking at some where short of $300 tops
jack stands $30
floor jack $30
18mm Deep Socket
18mm closed wrench
13mm closed wrench
crescent wrench
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
landyacht33
- Year and Model:
come to florida and well do it for free
- 989 Views
Last post by dosbricks
- 286 Views
Last post by FCPEURO
- 308 Views
- 513 Views
Last post by detailjohn
- 382 Views
