I have the ECC unit and it usually only blows at max speed when key is in KP II position or engine is running. Sometimes when I start engine, blower will not blow at all even if I move climate lever from AUT to max, but I can hear clicking noises that seem to be coming from the blower resistor/power stage near the blower motor. The blower does not stay on when engine is off or if I turn ignition off.
Background info:
- blower motor has never squealed or made noise. I took it off and it spins freely, so I lubed it with "Liquid Wrench".
- checked ECC module and there are no burn/scorch marks inside top cover or on circuit board.
- cleaned temperature sensors near grab handles on driver and passenger side (they were thoroughly gunked with lint/dust so just sprayed them with compressed air).
- tried to check the B-1 codes but got nothing, although could get codes from some other ports.
- since I live in Southern California, I don't use the heat/AC that much, but I did notice several months ago that even when I turned the heater on with AC off, cold air would still blow out of the vents (perhaps because of the gunked up sensors?). However winter is here - well, we call it winter
- all parts are original and have never been replaced.
From everything I've read so far, it seems I probably have a faulty power stage.
Also, I've pulled the dash apart and can see the power stage to the left of the blower with the black and blue wires, but can't figure out how to get it out. There seems to be one screw holding it on but it's really hard to get to as there's a metal bracket in the way. If I can take that screw out, does the power stage just slide out? Is there an easy way to get it out?
Is there anything else I should check or look for?
If everyone agrees that's it's probably the power stage, should I get new or used?
Should I get it from ebay or can anyone recommend good local parts yards in SoCal?
Like most folks, I'm trying to nurse the car along a bit longer and keep expenses down.
Sorry for the long post.
Thanks in advance for any help you can provide.
