Blower, heated seats and lights not working
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Bski902
Year and Model: 2000 Volvo S80
Post by Bski902 »
I just had a front left axel, inner tie rod and brake pads replaced on my 2000 s80. As I was leaving the shop, I noticed that the blower, heated seats and lights were not working. Any thoughts or experience with this issue? Any help is greatly appreciated. Thanks, Bill
yuckuJackD
Year and Model: XC70; S80; S40
Been thanked: 2 times
Post by yuckuJackD »
Check the fuses:
7 Heated front seats - left 15A
8 Heated front seats - right 15A
26 Control module - climate control blower 30A
Which lights are not working? Interior, headlight, low beam, brake ...
I think it's a mistake of the shop. While replacing the mentioned parts they made a short or cut/disconnect a wire, probbably by mistake without knowing but... I suggest you to come back there to correct that with no charge...
Good luck
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
Bski902
Post by Bski902 »
Thank you very much for the response! I should have mentioned that I did already check all of the fuses. The mechanic is trying to help, but cannot seem to figure out the problem. I'm worried about cost, but would also like to stay warm. Any other advice?
