2006 s60 climate control problem
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
normf
Year and Model: S60 2006
Post by normf »
Had a new ac compressor installed August 2010 after months of problems. AC worked like a champ and on a long trip just got colder and colder. It was a hot summer and I didn't mind. I leave it on 'automatic' at 72 degrees all the time. Probably should have noticed something wrong as it got colder than 72, but Iwas just happy to have AC.
Then when we hit colder weather, the AC just kept overpowering the heat. In fact the only way to get warm was to set the temp to max temp. Took it back to the mechanic who told me the climate control software needed to be reloaded. That seemed to help, works great for about a 1/2 hour and then the AC starts to overpower the heat and it starts getter colder and drops well below the auto setting and keeps going unless I change to max temp manually and then the heat goes thru the roof.
Any ideas on what the problem is?
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Could just be the ECC unit itself. Do the REC and AC lights flash when you first turn the heat on?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The temp sensor for car interior is behind those slots on RH side of face of panel. It will be dirty down inside if you look. Try blowing that with one of those canned air things for computer keyboards. The sensor is serviced separately. The best way to diagnose the problem is with VIDA or VADIS where the sensor temps can be read. IF the temp sensor gets biased (reports a temp that is wrong, for your car that would be hotter than actual temp) then the system will not work well in auto mode.
normf
Post by normf »
FCPGroton wrote:Could just be the ECC unit itself. Do the REC and AC lights flash when you first turn the heat on?
Just double checked that- I'm getting no flashing of the REC or AC lights. Just steady on.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
remove the ACC module and clean the cabin temp sensor.
normf
Post by normf »
jda2000 wrote:remove the ACC module and clean the cabin temp sensor.
OK, tell me where exactly to find the AC module? Thanks.
jda2000
Post by jda2000 »
the ACC module is the AC/heater control module the center lower dash
normf
Post by normf »
jda2000 wrote:the ACC module is the AC/heater control module the center lower dash
Thank you. Let me get to work trying to figure out how to remove it. Appreciate the help.
