I have a 2004 XC70 with 85k on it. Just got a CEL today, went to check it and my OBDII reader would not recognize that there was a code. To confirm, I restarted the car and CEL remained. I checked it while running and the reader came back with "P2177 - lean off idle" and there were 2 instances recorded. I was able to clear the code but only when the car was running. I know you are supposed to be ignition on - engine off when doing this but its the only way I could read and erase the code.
Does anyone have any info regarding this code? I searched the forum with no results.
Thanks!!
I should add that the car was not and is not experiencing any rough idle or abnormal symptoms.
Code question
Code question
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
Here is a similar thread for your reading http://www.v70xc.com/forums/showthread.php?t=14901
You can google Volvo P2177 code and come up with a bunch of hits. From quick reading it looks like anything from a vacuum leak to the MAF sensor as stated in the above thread. I've never personally experienced this code so I can't be of much help.
