2006 S60 removing climate control panel in passenger compart
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
normf
Year and Model: S60 2006
Post by normf »
I need to access the AC temp sensor in the passenger compartment on my 2006 S60 sedan. How do I remove the plastic cover? Does it just snap out? I'm obviously concerned about breaking it or damaging the surrounding interior trim. What kind of tool do you recommend?
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Definitely get a bone tool to remove it. I believe it is just snapped in so you should be able to pull it apart.
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
lift the plastic cover around the shifter and push aside. You'll see 2 two torx screws at the bottom of the Climate Control panel.
Remove the screws and pull the CCM outwards.
