Had to get to the rear of the aftermarket reciever, so, I had to remove
the pen holder strip then the HVAC control panel (Climate Control Panel).
When I was done, I just left the panel in with the top hooked on and the
buttom hanging without pushing it inside the space; will be going back
to the receiver latter.
I did not unplug the battery before unplugging and plugging back the three
connections on the back of the panel. This morining, when I drove the car,
it had the message "SRS-AIRBAG SERVICE URGENT".
Would there be any relationship with not disconnecting the battery before
unplugging and plugging back the connectors on the back of the HVAC panel?
Or just a coincidence?
Thanks.
"SRS-AIRBAG SERVICE URGENT" After Removing And Replacing The HVAC Control Panel
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
One thing I've learned with these Volvo's, always disconnect the battery before disconnecting anything electrical. I would have expected an HVAC code rather than a SRS warning, but I think it is related with you not disconnecting the battery.
Just my opinion based on experience with my 2001 V70.
- SuperHerman
- Been thanked: 207 times
You didn't disconnect the battery and that triggered the code.
You can reset it with VIDA or bring it to a shop or the dealer. I did the same thing but had VIDA so I just reset it.
Yes - there is a relationship - hopefully you have VIDA or it may cost you $150 at the dealer.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
SRS light if the CCM is unplugged with the battery connected is a known thing on P2s.
I would guess it disturbs network communication between the SRS module -> CEM seeing as the SRS module is physically between the two on the network, unplugging the CCM disturbs the termination resistance on that end. Once the fault is triggered you need a vida to reset/turn off the SRS warning indicator light.
Oka
Well, I've learned. Will not happen next time (I hope). Maybe I would be careless since I now know I can easily clear the code. Yep, got the SRS error code cleared.
I really appreciate all the pointers from you all and will heed to all your pointers. Thank you all. Well appreciated.
- 27 Replies
- 27969 Views
Last post by cn90
- 1643 Views
Last post by KurtL
- 427 Views
Last post by rred
- 4245 Views
Last post by Legofan
- 13389 Views
Last post by mrbrian200
