I have a 2002 C70 LT with apx, 152K on it. I bought is with 146K 6 months ago for under 3K and would love to fix the following issues.
Luckily it is my play car so I have time to tinker with it.
1. When I make a left turn under acceleration a loud whirling sound (like the power steering pump is low on fluid but it isn't) is heard and it is loud.
The noise continues even after I complete the turn. The noise will continue getting louder as I accelerate and softer when I decelerate. But it doesn't go completely away until I come to a complete stop then accelerate. Meaning i hear it when the car is at a complete stop.
2. My transmission sometimes slams into gear, that occurs in first or reverse. It also will slip out of gear while driving. I swapped the upper rear engine mount and it made it much better, (not so hard shifting and not as often). I was wondering should I go and replace all engine mounts or just take it to the tranny shop?
3. And this is the most annoying. sometimes my car will crank the die quickly. I will crank it again and it just clicks. Then I take the key out wait about 30secs and without pumping the gas try to start it again and it starts just fine. This happens in the morning or if I make a few short trips. I replaced the battery, and the alternator and starter are newly installed.
I know this is a lot of issues, but the car is paid for and I would love to fix it.
Annoying issues from my '02 C70
izodmartin
- Year and Model: C70 2002 LT
Drive it till the wheels fall off... then put them back on!
2002 Volvo C70 LT Convertible 152K
2000 Volvo S80 T6 75K
JRL
- Year and Model: Several
- Been thanked: 16 times
Your tranny is on the way out
As for your noise, could be a wheel bearing
izodmartin
thx, I love honest straight forward answers.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Have you checked the the fluid level and condition? Reason I ask is a low fluid level can cause it to jump out of gear or make whining noises. Ie 1 & 2.
#3 "could" be immobilzer related. I was thinking MAF at first, but with the clicking Im changing my mind.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Starting problem: Check voltage drop between battery and block on (-) side while operating starter. Check V between (+) post and the brass stud with a heavy wire on it in the electrical box next to brake master cylinder with EVERYTHING in car turned on.
JRL
You can always try the drain and fill routine, (tranny) and add software but at 145k miles you really can't flush it, too many unknownsizodmartin wrote:thx, I love honest straight forward answers.
izodmartin
Thanks to all...
JRL... thats the second time I've heard do not flush tranny. Why not?
JRL
izodmartin wrote:Thanks to all...
Too many miles.
The odds of dislodging crud and having said crud find its way to a bad spot and completely ruin the tranny is high
izodmartin
OMG, fixed issue 1.
It was the power steering. The fluid was low, and thought it looked okay when I checked it. I replaced the hose clamp and refilled it. This problem is history.
- 1546 Views
Last post by SuperHerman
- 2172 Views
- 981 Views
Last post by jefflamonica
- 2178 Views
- 3366 Views
Last post by HerrGruyere
