Blinking climate control lights
Ocassionally, my AC and Recirc. lights will flash for a bit and stop. The manual states this is an indication of a problem in the heat/AC when it continues, but it only does this for a bit. Everthing works fine. Do I have a problem?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The light is programmed to flash for 20 seconds to tell you fault codes have been stored. Unfortunately, you need to use a code reader that can read AC faults.
You may think that nothing is wrong but these systems are so complex you may not notice a fault - yet.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
I don't think your "cheapy little reader" will read heater codes although they are read from the same data link connector. As for going to the dealer, we rarely point people in that direction. Check around at some of your local repair shops as some of them may have the required equipment. Mine does.
Bill.
Bill.
Previously:
Previously:
- 14 Replies
- 3795 Views
Last post by RickHaleParker
- 13 Replies
- 5417 Views
Last post by firstv70volvo
