During the replacement of the the right axle shaft assembly the control arm ball joint seemed a bit loose. I took a video . What do you guys think?
Thanks,
Greg
Control Arm Should I replace?
1994 Black on Black 850 Turbo Wagon. Miles? Odometer quit at 150K miles.
JRL
- Year and Model: Several
- Been thanked: 16 times
Why is this a question?
if it's loose you replace it
EstVolvo
- Year and Model: 2000 V70
It is hard to tell from your video since you are spinning it around and moving the whole control arm up and down. I need a reference point. I would replace it if I could feel ANY slack up and down or left and right. You have to grab the ball joint and the control arm an feel if they move as one. Once they start going bad they get worse quickly.
Where in Minneapolis are you fixing your car?
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 6 times
Being able to move it back and forth like that indicates it should be replaced. If you've done the inner tie rod, they should both be difficult to move, so that one's ready for replacement!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
JRL
Use an OEM Volvo control arm,NOT the CHEAP ones from groton or you will be replacing it again
- Has thanked: 292 times
- Been thanked: 765 times
+1 on the OEM control arms.
Don't learn this the hard way like so many others (like me) have: only use the Volvo-branded control arms.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Shop around for the best prices - the guys at the top of the web page are a good start.
'98 S70 T5
2016 Chevy Cruze Premier
It's a question because I don't know any better and have little experience repairing carsJRL wrote:Why is this a question?
Thanks JRL I will take this advice to heart. To some the answer may seem obvious but to the inexperienced, not so much.
Greg
- 12436 Views
Last post by MarcM
- 2619 Views
Last post by 800artfreed
