I'm helping a friend with a 78 244 DL:
Wasn't getting fuel, replaced the frame-rail pump, no dice. Went ahead and replaced the intank pump. And got fuel pressure checked at the filter under the hood.
When we changed the intank pump, the tank was DRY, bone dry, nothing, and the pickup filter was missing NOT floating around in the tank, yup, and of course the pump was clogged with crap. Additionally the 2 fuel lines to the pump had the clamps already loosened and slid-back as if just taken off, interesting.
Tossed 2 gallons in it, cranked it a good 30 times and finally got enough fuel to run. Drove it around the block. Accelerated extremely poorly, as if not getting fuel.
Now it will crank-start- idle for 0.5-1.5seconds, die.
Turn the key to the run position and can watc fuel gush out of the filter if I loosen a fitting at all.
When it dies I can hear electrical (maybe fuel pump still going, maybe a relay ?) sounds for a second or two.
Air in the fuel lines? Still not enough fuel in the tank? Some crap sucked up and cloggin a fuel line?
Found the distributor cap to be half-on properly, so the contacts are somewhat scarred, but I've seen much worse still run fine.
The vehicle is kinda ghetto under the hood: butt-splices on O2 sensor, Cam sensor (sensor inside distributor), ignition coil, etc. Looks like someone had a field day under the hood of it.
Open to suggestions ! Whats your thoughts?
Saul
78 244 DL Starts, Runs, Dies, Repeats
Gumcrew2
- Year and Model: 96 850 GLT
"When Murphy wrote his law he was thinking of you"
96 Volvo 850 GLT GONE (replacement coming soon)
91 Jeep Cherokee 448K, Turbo Stroker, Lifted, Locked, Caged.
83 Ford Ranger, F250 brake system/ sway bars : )
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Sounds like a crackhead was working on that car. I would go over everything. If the fuel pressure is ok and flowing well through the injectors (K-Jet car I assume), check to make sure the place is aligned correctly. If that is all set then you need to make sure you are getting good spark to all of the cylinders.
Check all of that and let us know what you find.
- 2809 Views
Last post by Skidplate
- 2073 Views
Last post by erikv11
- 3166 Views
Last post by bharman
- 1273 Views
Last post by RickHaleParker
- 15 Replies
- 6675 Views
Last post by BoomerFT
