07 XC 70 door panel disassembly?
SC-816 CD Changer and iPod Switcher
So I succeeded in putting my knee through the speaker grill on the drivers door this winter via a slip on the ice. Got the new speaker grill from the stealership ($39). Just need a little guidance on removing the door panel to replace the grill. Thanks Matt
Reason: Removed extra "??" characters from title.
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
I had to remove mine once a few years back. If I remember correctly, there are little round plugs located along the edges of the door panel, they have even smaller round center pieces. Use something pointy and push in the centers of each plug, that releases the clips. I think all you do then is lift upwards and remove (unplug all electrical connections from the back).
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
Well that was most of it. There is also 2 screws (Torx) hidden behind a beauty insert on the large handle you use to close the door. Once you get those 2 removed and the push pins on the perimeter of the door it does indeed lift straight up. Now you must remove the door cable and the 3 wiring harnesses and viola', it is off.
- 1800 Views
Last post by VolvoChef
- 1053 Views
- 582 Views
Last post by jmana
- 21 Replies
- 5693 Views
Last post by precopster
- 802 Views
