1998 v70 t5 Key fob ... programing
Pre-2001 V70/S70 Key Fob Programming
JRL
- Year and Model: Several
- Been thanked: 16 times
Dealer only No software required on a 98, so it's a 5 minute job, however.......
I sure hope you bought the right one (and not an Ebay deal) sealed in the Volvo packet that has the numbers.
If not, you're probably SOL
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
You mess with too many cars, Jim. A '98-'00 is pretty simple.
No numbers needed and an eBay unit will do.
(As long as it still works!
Volvo P/N 9166200
If you have one of these and a
dealer nearby, you're good to go.
Volvo P/N 9166200
JRL
You know damn well that a 99-2000 needs SOFTWARE and the blank is not the same as a 98BEJinFbk wrote:You mess with too many cars, Jim. A '98-'00 is pretty simple.
(As long as it still works!)
Volvo P/N 9166200
- BEJinFbk
I was not making any reference to the key.
OP is looking for a remote only, as I read it.
I agree that the key for a '99-'00 is a spendy bit of fun.
Sign me - "Loving my ' 98 more and more each day!"
jimmy57
- Been thanked: 322 times
The 98's need the PIN plus Volvo Scan Tool to program in. If there is an aftermarket scan tool that does it I do not know of it other than the VST purchased through its maker as Autodiagnos. Some indy shops
use that tool.
99 -2000 S and V and the 99-2004 C need VIDA. The PIN is handled through a software download and programming is done once the software PIN is obtained.
Keys on 99 and later ALL have to be programmed using VIDA. Some 98's in Canada had immobilizer and keys have to be VST plus PIN programmed on those.
Remotes on 99 and later P1, P2, P3 all require new GENUINE remotes so that you have the programming alphanumeric code strings plus VIDA.
There is no cycle key X times, press buttons shortcut on the VGLA 800 platform cars.
use that tool.
- BEJinFbk
I stand corrected and once again,
find myself very happy to own a '98...
( I like simple! )
Thank you for the clarification, Gentlmen.
And - Special Thanks to Jimmy for the technical details.
I don't know if you've been getting any feedback, but your posts
and technical expertise are a true and valuable asset to MVS.
My hat is off, sir!
( I like simple! )
My hat is off, sir!
darbytomusa
- Year and Model: 1998 V70
98 V-70 Guess I am a little late learning on this one having bought two on ebay and finding out I can't reprogram them. Actually I only needed the cases so I am not too bad off, But they were rather expensive cases!!!
- rainman
- Year and Model: 2000 V70SE
- Has thanked: 1 time
To jimmy57 or anyone else that can help ?
I have a 2000 Volvo V70 SE non- turbo. I purchased an oem uncut/ unprogrammed key from Tasca Auto parts. I am bringing the key to a volvo dealer to have it cut and programmed. I have read in a few different places that the 2000 V70 that has a flashing security light on the dash "does not" have to be programmed by the dealer and that I can program or link it to the key myself?
If anyone knows for certain whether it can or cannot be done by me, please let me know.
I already have the original key and 9166200 remote keyless entry, but I wanted to have a backup.
Thank You, Ray
Thank You, Ray
- Been thanked: 4064 times
Upthread a bit..if you don't have VIDA it is off to the dealer...
- 3325 Views
Last post by jtp
- 12 Replies
- 2841 Views
Last post by Ozark Lee
- 1868 Views
Last post by sparky65
- 4148 Views
Last post by precopster
- 2396 Views
Last post by krhodes1
