Welcome to the site. That's a bit of a weird combination of codes. I'll be the first to say that I have no idea what the 1-3-4 on the transmission module means.
"134 Faulty load signal from ignition control module"
The 2-3-1 is almost certainly vacuum leak. Look over all your vacuum lines and replace where necessary; this causes the car to run overly rich and is robbing your gas mileage.
Hopefully someone else will know what that 1st one means. I'd suspect the throttle position sensor is tied to that code, but it has its own seperate code that would also be thrown on A2.
'98 S70 T5
2016 Chevy Cruze Premier
