radio/tuner/cassette player
i have a volvo v70 year 2000 it has a volvo radio cassett in place at the moment i would like to replace it with a volvov70 cd/radio /tape player should it fit in without any problems please thanks mike. :
VolvoTurbo850
- Year and Model: 1994 850 (T5)
yes should slide right in. Just make sure you get the radio code when buying the new one.
In some cases you might just want to get a retrofit kit if your not looking to keep your car original. It will occupy just half of your double din unit. The other can be substituted with a cubby hole for your CD's and other things.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Unless you're like me and obsessive about a total OEM look on the dash, do what they said, get an aftermarket. sonicelectronix.com has a bunch of double-DIN and some look fairly plain. Don't believe crutchfield; a double DIN will fit beautifully, you just have to take the rails off.
If you really want to stick OE, you want the SC-815 or SC-816 (same, one is black, other is gray) single-CD unit; it has the proper bass emphasis for your wagon. Or, you could go higher end and get an SC-901 three-CD, but the cartridges tend to screw up and that unit requires the external OE amplifier. However, the -901 is made by Alpine, where the lesser units are Mitsubishi.
Either way, since you have a V70, (P1, right? no "hips" on the side?) you should consider the Dynaudio factory upgrade speaker kit. Search around the forums. Don't fool around with aftermarket speakers; you could spend $10K on a competition reference system that takes up your whole cargo area and cuts into your panels, and not match what those Dynaudios can do without a single visible change.
5 others that came and went
