I've been reading info on this forum for about a year now and it's been very helpful (thanks). I finally decided to sign up because I've got a couple of fairly important questions that I need help with. The car's a 1999 XC with about 135K miles on it. It actually runs great except the stuff below. In the last year, I've changed timing belt/ water pump, front suspension, 3 motor mounts, had Victor rebuild the ABS module, the entire coolant system (including heater core and radiator) and other miscellaneous stuff. Here's the issues now...
1. It's been blowing smoke (oil) out the tailpipe. I didn't know this could be PCV until yesterday. I did a compression check, and all 5 are low (about 15-20 lbs) but even. I was looking for a head gasket leak but... We put a little oil in each and they came up to spec PSI. To me, this says the rings are worn.
2. I was backing up into my drive, hit a bump at the end and lost reverse. It literally felt like it shifted into neutral. I'm not a transmission expert, but I'd think a clutch would slip for at least a while before it gives out??? It did shift late and hard (through all gears) one time a couple of days earlier when it was cold-- but never before and never since. I did the drain/ fill/ drive/ repeat with Mobile 3309 a year ago.
So my question is, should I pull the whole thing and rebuild/ replace them both? Could either be something other than rings and clutches? I have no problem doing the engine rebuild, but I'd rather not if it isn't necessary. I've never done a transmission, but I wouldn't be afraid to start. Plus, I know two ASE tranny re-builders who would do it on the side pretty cheap. From the forums I've read, rebuilding the tranny is either very easy and idiot-proof, or shouldn't be attempted.
I have some time off coming up and would like to get this car going. Any advise would be appreciated.
Thanks,
Aaron
Replace/ rebuild engine and tranny?
airstar1199
- Year and Model: V70 XC 1999
If the car is cosmetically awesome and you are comfortable with the work, give it a shot. Personally, I would likely buy engine with a good bottom end (not hard to find) and a tranny attached. do the head reconditioning and rear main seal and you are likely to get many miles of happy motoring.
1998 V70 GLT, 15G swap
Fairfield, CT
Fairfield, CT
VolvoTurbo850
- Year and Model: 1994 850 (T5)
agree that it is easy to find bottom ends and tranny so you do not have to really get that involved with that complicated stuff.
I wonder if your pnp or shifter has become misaligned? Regardless might be worth the exchange.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
