2002 S80 T6 timing belt change
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
davidj
Year and Model: s80 2002
Post by davidj »
Is there special tools? does the cams need to be locked.A book on timing belts says to align timing (cams)wheels then rotate 1/4 turn on crank bolt - then back to alignment .Thank You
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
VADIS instructions are attached. I have included the optional part about the timing cover front as I don't know your chassis number.
S80 timing belt.pdf
(206.91 KiB) Downloaded 1416 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
mlanctot
Year and Model: 1999 S80T6
Post by mlanctot »
I'm helping my son with his 99 S80T6. We can't get the center bolt off to change timing belt. We spayed penetrating oil on it and let it sit over night. Is it OK to heat it up mildly? We are kinda stuck till we get this off. Thanks.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
:o
what center bolt are we talking about here? Exhaust cam pulley? Its torqued to 80ftlbs to it will take a bit of force to do it.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
mlanctot
Post by mlanctot »
I'm talking about the fly wheel center bolt. We got the timing belt off with this. Found two burnt or broken exhaust valves. How can 2 fail almost simultaneously? I'll get a quote before going forward. One other thing I noticed. A slight amount of pitting on the edges of some lifters. I've never seen this before. its not where the cam comes into contact but odd.
boosted5cyl
Ah, that bolted is torqued to 300ftlbs. I dont actually rememebr how I got mine off. I know it involved a torque wrench.
Thats odd about the lifters though. Chrome plating chipped off them?
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Post by 537playing »
I used a n electric impact drill to take off that bolt. I was very careful not to use too much torque.
mlanctot
Post by mlanctot »
Lifters weren't chipped but looked like they were pitting with rust on the edges. The shop said to look at them again, probably just crud. I have decided to have the head rebuilt locally. 450-600 New seats, clean, a few valves and fly cut the head.
