Need to remove radio 2002 xc70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
iamjoe
Post by iamjoe »
My 2yr old son decided that he wanted to insert coins into my cd slot. I need to get the radio out and try to remedy this.
Any step-by-steps out there?
Thanks
uhh...
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
If it is like the 850 HU, there should be two levers on each side that you push in and they pop out. Then you just pull it out.
If it is like the S60 unit, then you remove the bottom pen hold, then the CC and then the radio. It is all held in with clips and a couple torx screws.
Good Luck.
