IPD sale Volvo Parts
fuel door won't open
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
lgoldsby
Year and Model: s80 2000
Post by lgoldsby » Mon May 23, 2011 7:25 pm
I just got a 2000 S80 with 94,000 miles a few days ago. Yesterday, we found we could not open the fuel door. We've tried locking and unlocking the car and changing the fuse, but it still won't open. It worked fine on Friday. This is one way to conserve gas. Any ideas?
dcarlson12
Year and Model: 1997 850 T5
Canada
Re: fuel door won't open
Post by dcarlson12 » Tue May 24, 2011 6:01 pm
I imagine there is a solenoid which activates the lock. I believe you might be able to access it from the trunk. Maybe try to apply 12 volts to it to see if it will activate it. I would isolate the solenoid so as not do damage to the input circuit since it is probably sensitive to polarity. As a short term I am sure you can access the actuator via the trunk and manually actuate it... Others with more knowledge please chime in......
moondogy2045
Year and Model: S80, 2000
Post by moondogy2045 » Sat May 28, 2011 4:14 pm
lgoldsby,
This is a common problem. Open the trunk and look to the right for a handle used to release the rear seat. Next to this handle is a knob. Turn the knob counter-clockwise to release the vertical carpeted truck panel, then pull the panel from the top to expose the wheel well/sheet metal. Use a flashlight if needed and look for the area inside the trunk where the fuel door is located outside the car. You should see a black solenoid-operated lock. There is a small white plastic ring around the movable locking shaft. Just pull this backward (toward the back of the car) to release the lock. If you do not plan to replace the lock (and to prevent it from re-locking the door) just disconnect the electrical connector. The lock may be removed by simply removing the electrical connector and the 2 mounting screws that are accessed from outside the car, inside the fuel filler door.
Hope this helped!
Moondogy
Please post your results for others.
Who is online
Users browsing this forum: No registered users and 24 guests
