enlighten me on two sizes of front rotors?
This topic is in the MVS Volvo Repair Database » DIY Smoke Tester Tool
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
I'm going to do brakes on a family members XC90...it's a 2007 with 3.2L engine. When I search parts on several suppliers sites they show (sometimes) two different diameter rotors! Did they shift mid-season or is this different from V8 to 6 or another option?
The vehicle is not near me and I'm hoping I don't have to make a long trip just to pull a wheel and measure the rotors...and her doing it is not an option.
Is there anyway to figure this out from 20 miles away?
Thanks.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
TexasCoder
Year and Model: 2004 XC90 T5 AW Tran
Post by TexasCoder »
I had the same issue on my '04 XC90. I took the wheel and rotor off, and it was stamped on the inside portion of the "hat" of the rotor (316mm).
But, in your case, I would get the VIN number and call the dealership. They should be able to tell you the size that is on there. If not, you have two less attractive options: buy both rotor sizes, send the wrong size back after you do the job, or drive down there and pull a wheel off :-(
Let us know how it turns out!
carboncow
Post by carboncow »
Thanks, I like the VIN idea.
So from what we can tell there is no rhyme or reason to the rotor selection? Just whatever was on the floor that day at the factory?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
jimmy57
Been thanked: 320 times
Post by jimmy57 »
316mm, 316 and 335 are the choices on 2007 and V8's get the big ones.
carboncow
Post by carboncow »
Now that is what I would expect!
Thank again and again Jimmy. I'm just going to start PMing you directly at this rate!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
TexasCoder
carboncow wrote:Now that is what I would expect!
Jimmy is officially my goto guy also, but if we start messaging him, I would suggest he charge a flat rate per answered question! :D
carboncow
Post by carboncow »
It might be worth it...his answers are spot on even for questions nobody else touched for days. Volvo tech or just been around the garage to long? As he's answered questions across models.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
