1996 Volvo 850 R engine knock updated video!!
uconnmike24
Year and Model: 850R 1996
Post by uconnmike24 »
MY CAR IS A 1996 VOLVO 850 R I AM THE SECOND OWNER RECENTLY MY ENGINE HAS BEEN MAKING A RATTLING NOISE WHEN I REV THE ENGINE WHEN ITS ON IDOL THE CAR SOUNDS QUIET AND AS YOU SLOWLY START REVING THE ENGINE AND REV IT HIGHER AND HIGHER THE RATTLING GETS LOUDER AND SEEMS TO BE MAYBE A PISTON LOSE OR IF NOT IM NOT EXACTLY SURE WHAT THE PROBLEM IS IF ANYONE HAS ANY SUGGESTIONS AND IF I SHOULD TRY TO FIND A NEW ENGINE OR IF THERE IS A WAY TO FIX THIS THAT WOULD BE GREAT IT STILL DRIVES FINE BUT MAY NOT BE FIRING ON ALL CYLINDERS AT THE MOMENT THANKS A LOT FOR LOOKING AT MY QUESTION HOPE TO GET SOME IDEA OF WHAT IS WRONG SOON.
Here is the link to the updated video if anyone is local and in Connecticut that would be great if you had time to take a look
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
First, no need for caps, it is annoying.
As for the sound, it sounds like bad lifters. When was the oil last changed? Is the maintenance up to date?
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
+1 on the bad lifters. The clacking if you listen carefully comes and goes a bit. A bearing rumble or knock would be a deeper noise.
20 OEM lifters from IPD is not too expensive if I remember rightly. I'd replace the set as it is bloody hard to find which ones are the loose ones! And look at replacing your oil pan O rings while you are at it.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Post by jblackburn »
Probably litters being starved for oil by bad o-rings at the oil pan. Try those first.
'98 S70 T5
2016 Chevy Cruze Premier
uconnmike24
i have been constantly checking the oil bc recently i have had a oil leak from the rear main seal which seems to be a problem with these cars i would like to change the lifters is it a hard job and time consuming?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
do the o ring replacement in oil pan first. Aerated oil will cause tappet bleed down and tappets may not be needed if the o rings on oil pickup tube are failed and letting air in.
