Sorry I bought the double size can and the gauge that came with it... but for the life of me I can't find where the quick
connect is, that would match what size the hose it.
I see something at the top of the engine that is about the size of a hair spray cap but that can't be it.
Is there a picture of this thing that would resemble an S60 somewhere.
THANKS !
MY AC pulley went bad last winter so thats why I have to fill it up I'm assuming since it got a used one.
Can't find where to recharge AC 02 s60T
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
hmmmm I cant quite tell where you are pointing to.
Is it evident in this pic?
http://images.gtcarlot.com/pictures/44675806.jpg
- Smarzig
02 S60T 17"rims
02 S60T 17"rims
jblackburn
See that little cap hidden there by the PS reservoir that says MAX 6 nm? There's your low-side port.
NOTE: If the system was completely drained, moisture is now in there, and it should be evacuated by a shop and recharged. The receiver/dryer should probably be replaced as well.
'98 S70 T5
CountryBum-kin
- Year and Model: S60 2002
Exactly what he saidjblackburn wrote:See that little cap hidden there by the PS reservoir that says MAX 6 nm? There's your low-side port.
go 2 x 2 guy
- Year and Model: S60 2001
That is one of the best pictures/reply I've ever seen on any BB.
KUDOS to that man...and then some.
jblackburn
Screws off, should just do it with your fingers. Lefty loosy. If it's stuck, grab it with a set of pliers.
'98 S70 T5
phislamabama
- Year and Model: 2002 S60
Great picture, helped tremendously. Now, I am hearing a hissing sound after A/C is turned off. The refrigerant I bought is supposed to seal any leaks. Does anyone know how long I should wait to make sure it's sealed?
