Reset maint overdue on dash
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
millerboy
Year and Model: S80 2008
Post by millerboy »
How do you reset the maintenance overdue on the dash on a 2008 S80?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
DO not touch brake pedal!
insert key into its slot.
push the button for 1 sec, depress trip reset button and with the other hand push the button for 2 seconds and do not release the trip button until you see the amber warning triangle flash 2-3 times.
Turn off ignition then depress brake pedal and start engine to assure the message is gone.
If not, repeat process but be sure the accessory stage is all that is on when you depress trip button.
