2001 Volvo V70 HU Upgrade
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
johnrapier
Year and Model: 2001 Volvo V70 T5
Post by johnrapier »
Hello everyone,
This is my first post in this forum. It has been very useful so far as I have replaced my ball joints,control arms, and inner and outer tie rods from the help of this forum. My question is and probably has already been answered before.
The current set up in my car is the Dolby Pro Logic system with center channel and sub woofer, this system is perfect and don't want to change anything, except for the head unit. I'm looking at replacing the factory hu with a after market double din with navigation. My only concerns are the following:
1. Is there anyway to use teh factory amp with an aftermarket unit.
2. Is there anyway to keep the functionality of the center channel, if I get a n aftermarket unit with 5.1 capabilities.
Any suggestions would be very much appreciated.
Regards,
John
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Nothing wrong with an 803
Add a subwoofer and USE THE HIDDEN MENU to adjust your sound
johnrapier
Hello,
It already has the subwoofer, I'm trying to add navigation/bluetooth/satellite to my car. All I want to do is to change out hte head unit, keep the factory amp with the factory center channel and subwoofer.
JRL
Post by JRL »
There are only one or two aftermarket HUs out there that have a center channel as far as I know.
The Volvo amp is prone to overheating and even if it can be mated up, by the time (cost) you'll have in it by re-doing all the wiring, it would be easier to pull everything out and go with a better aftermarket AMP that would match up better to the new HU
ojdorson
Year and Model: 850R, 1996
Been thanked: 3 times
Post by ojdorson »
You need something like this. http://cgi.ebay.com/ebaymotors/Volvo-St ... 456wt_1172
I've made my own, but if you're not good with soldering it's probably easiest to buy it.
ojdorson
Post by ojdorson »
Oh, and you will need to look long and hard to find a receiver that will power a center channel speaker. In your car, the center channel speaker is powered by the head unit, NOT the amp. I'm looking on www.crutchfield.com now.
DGM
Year and Model: V70 2.4i 2005
Post by DGM »
johnrapier wrote:Hello everyone,
Regards,
John
Bluepower may have what you are looking for.
I installed the BLP-840 recently.
You can retain your factory amp or upgrade it.
The BLP-890 model fits your year/model.
http://shop.textalk.se/en/article.php?i ... rt=5980331
I feed the central speaker in mono and adjust its level with an L-Pad.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
johnrapier
Hello,
And thank you for the quick reply. Do you have an IM that we can talk thru. I'm in the USA do you know if bluepower is sold here.
DGM
Post by DGM »
johnrapier wrote:Hello,
Members of our local Volvo Club bought 3 units from Sweden last winter. I know some units were delivered to the states. We had to resolve bugs with the supplier on these early production units. Software updates were provided to update their firmware. Now they operate normally and their documentation has improved.
http://forums.swedespeed.com/showthread ... -Version-3
http://forums.swedespeed.com/showthread ... stallation
The unit doesn't have a dedicated output for the central speaker as on your Volvo HU. I made my own with an L-Pad tapped to the + of the left channel and the - of the right channel. I adjust the level through the L-Pad potentiometer. The adjustment is done at the installation and the potentiometer is hidden under the central speaker. It is working well and you can adjust it at your convenience.
http://colomar.com/Shavano/lpad.html
http://en.wikipedia.org/wiki/L_pad#Speaker_L_pad
50 watts was sufficient for my application.
You can also do it with fix resistors.
http://www.sengpielaudio.com/calculator-Lpad.htm
Regards,
