I'm really hoping someone can help me with this. My car overheated, Again. There are no leaks that I can see aside the small drips from what I think is the A/C. It doesn't smell like coolant anyway. Still, the expansion tank is not going below the min level. The fan is coming on like is should, no leaking from the radiator and the coolant line that was fixed last week is holding firm. Could my water pump be bad? Maybe the intercooler has something to do with it? I'm so lost........
I took out the thermostat last week and have been running the car without it since. I also have been using only water to fill the expansion tank. Could these two things cause the car to over heat? I drove it today about 50 miles in 89 degree heat with the A/C Blasting and made it to Waikiki with no problems. On the way home, ( a 22 mile drive at 10:30pm) I made it 3 miles from my house and it overheated. There was a 5 min bit of stop and go as they where doing road work. After I pulled the car over and shut it down I waited about 30 min, filled it back up with water, 1 quart of oil and drove another 10 miles, to my house then my other job. Seemed to be okay. The hood wasn't even warm.
Any and all help or suggestions to help me try to figure this thing out would be great. I just got a better gig but it is on the other side of the island and I don't think driving over the Pali is an option at this point. I really need that job and I don't fancy riding the bus.
John
p.s. Could the water pump be bad but not leak?
