arm rest
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
arm rest
Post by carboncow »
Any good procedures on fixing the arm rest? Searching has turned me up nothing although I know this is a common topic as about half the used ones I looked at had the pad broke at the axis assembly...I"m just not seeing how to get this apart and I'm hoping it doesn't require the entire center console to come out.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
"Fixed" how?
What's wrong with it? (that would be most helpful)
If it's the leater/vinyl I have a fix, if it's physically broken, that's another matter
carboncow
Post by carboncow »
Sorry for being vague I figured it was a pretty commonly know...like I mentioned over half of them I've seen used have this issue!
Here is a photo of the concern. I think it tended to happen to the ones with the silly rear cup holder insert creating additional stress on the cheap plastic parts. I hate pulling center consoles out...had a BMW with the same issue, boo!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
JRL
Post by JRL »
A real PIA to remove and replace, it's hard to explain
It's easier to just buy a complete used assy from someone like erie
www.erievovo.com. call them on Tuesday
As long as you have the right interior code, they should have several there
To install the single pieces could wind up costing just as much and it's a SOB to get right
carboncow
Post by carboncow »
Thanks. If that's the case I'm just glue the whole damn thing shut!!
I heard good things about Erie...I'll give them a ring.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
carboncow
Post by carboncow »
JRL wrote:A real PIA to remove and replace, it's hard to explain
http://www.erievovo.com. call them on Tuesday
JRL,
Do you anyone know if the newer 2005-2007 are replacement that will fit the older 2001-2004? They are obviously different looking but have to fit in the same footprint.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
JRL
Post by JRL »
I don't think so
