Subframe Lowering
OhioTec1
Year and Model: 850 GLT 1994
Subframe Lowering
Post by OhioTec1 »
Greetings,
I am currently in the process of replacing the steering rack in a 94 850 wagon. Everything is disconnected and all thats left is to extract the old rack. I do not have a floor jack that is able to raise the car high enough to fit jack stands behind the rear subframe mountings (I have a 15" max jack and 13.5" max stands). Would it be safe to place the jack stands on the front crossmember of the subframe, while lowering the rear portion of the subframe with the floor jack? I don't want the crossmembers slipping out of the stand cradles and I don't want to bend the subframe either!
Any advice would be much appreciated
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Pile heavy stuff in trunk and place jack stands aft of the rear subframe attaching bolts and plates. The items in trunk will help keep rear down so the car has far less, if any, tendency to teeter-totter on the stands. You will not be able to lower the subframe if the stands are holding car up by any portion of the subframe.
Loosen the front subframe bolts 5-6 turns so the forward attaching points have enough "give" to allow the rear to drop.
OhioTec1
Post by OhioTec1 »
Thank you, Jimmy57. I was able to get a hold of some shorter jack stands and set them behind the subframe. I was able to drop the subframe, no problem with a floor jack
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
Tip: The bolts that get in the way of sliding the rack out the side are pressed in and can be knocked out making that process a lot simpler and requiring less sub-frame drop.
1998 V70 GLT, 15G swap
Fairfield, CT
brucek2080
Year and Model: 1994 Volvo 850
Post by brucek2080 »
Thanks for the tip, it helped greatly. I've almost got the old rack out...now I'm having difficulty removing the power steering lines that go into the rack. they absolutely will not budge. Any tips?
Bruce
________
850 '94 - 200k
