Right so I have just started on a new project, an 850 R manual estate bit beat up on the outside but seems to be running pretty good for the age.
I noticed when first driving it home that the factory boost gauge was sitting pretty far into the vacuum section on normal idle and didn't boost much past the 12 o'clock into the boost section when on max boost. After installing a boost gauge running off the factory line running into the cabin it sits on about 20psi in vacuum at idle and will boost up to about 10 psi at max boost. Knowing that factory boost on these is about 10-12psi Im not too worried about the boost side of things but should it be sitting so far in the vacuum area at idle?
Any help would be great
850 R Boost Woes
Aussie850R
- Year and Model: 1996 850 R Estate
1996 850 R Estate
1994 850 T5R Sedan
1994 850 T5R Sedan
Aussie850R
Good stuff.
Thought I may have a leak somewhere. Checked all of the intercooler hoses and the line to the guage but couldn't see anything overtly wrong. You've just saved me ripping everything to pieces looking for a hole/crack that that doesn't exist.
1996 850 R Estate
1994 850 T5R Sedan
1994 850 T5R Sedan
- 21 Replies
- 5508 Views
Last post by j-dawg
- 11 Replies
- 1768 Views
Last post by erikv11
- 1875 Views
Last post by precopster
- 26 Replies
- 3827 Views
Last post by Cookeh
- 19 Replies
- 3142 Views
